1/10/2019 2:45 PM | |
Joined: 8/3/2009 Last visit: 9/20/2024 Posts: 13753 Rating: (1734)
Hello it depends on what you want to do. Programming a Comfort Panel you need TIA Portal thats clear, but if you want to use PN or DP Direct Buttons or PN diagnosis then you need a gsdml file for the comfort Panels. the files and everything is described in this FAQ: https://support.industry.siemens.com/cs/de/en/view/73502293 Bye Murof |
