2/3/2020 12:04 PM | |
Joined: 3/1/2018 Last visit: 6/1/2024 Posts: 1 Rating: (0) |
Hi Can you please provide an example on how to connect and query a MsSql Database, like SQl Express 2014 ? I'm trying to use the default js snippet for database connection but I'm not able to undestrand whitch connection string to use .
Errors Message: [Microsoft] [ODBC Driver Manager] Data source name not found and default driver not specified. There are other settings to do on the PC or in Tia Portal for database connection? Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/04/2020 05:59:40New subject after splitting |
2/4/2020 7:12 AM | |
Joined: 7/5/2013 Last visit: 9/18/2024 Posts: 3112 Rating: (512) |
Hello redeer, if you are looking for a solution with WinCC Runtime Advanced, see the following: How do you access an SQL database in WinCC Runtime Advanced using a script? Regards, Frink |
Pi is exactly three! |
