4/27/2020 12:45 AM | |
Joined: 4/5/2020 Last visit: 9/13/2024 Posts: 32 Rating: (0) |
please can you show me by an example in wincc flexible actually i have the same problem i want to move between my array elements i have 4 array in my data block db1.array_1[0..10], db1.array_2[0..10], db1.array_3[0..10], db1.array_4[0..10],i want to use four IO fields when i press a button all four values will be saved in may array as follows array_1[0]=first entered value array_2[0]=first entered value array_3[0]=first entered value array_4[0]=first entered value when i press button next the next entered values should be saved in my array element [1] an so on , ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/27/2020 12:42:08New subject after splitting |
4/28/2020 1:55 AM | |
Joined: 7/5/2013 Last visit: 9/19/2024 Posts: 3112 Rating: (512) |
Hello EDBSPW, you can use a script for that. Please see Tips and tricks for creating scripts, section 2 and 3. E.g. SmartTags("CPU_Array")(i) where you can select the required index i. Regards, Frink |
Pi is exactly three! |
