3/28/2019 8:53 AM | |
Joined: 9/21/2012 Last visit: 4/25/2024 Posts: 3923 Rating: (444) |
Inadequate cooling in the panel? |
3/28/2019 11:12 AM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1050)
hi Juha, Also check the correct mounting of the ET200SP-station. The figure below shows the minimum clearances you must observe when installing or dismantling the ET 200SP distributed I/O system. This is neccessary to get the rejected heat away. You can find this information in this manual, chapter 5: SIMATIC ET 200SP Distributed I/O system hope this helps, regards, |
