7/12/2013 4:38 PM | |
Posts: 14 Rating: (0) |
Hello, attached you will find the connections that I have, also the configuration for this project. Thanks for your help.
Attachmentimages.zip (239 Downloads) |
7/12/2013 5:11 PM | |
Joined: 1/21/2013 Last visit: 3/19/2024 Posts: 4618 Rating: (705) |
Hi Ayzetina, Did you try to disconnect a wire from the channel and put an ammeter in series? The current flows? |
7/12/2013 5:17 PM | |
Hi |
7/12/2013 5:21 PM | |
Yes I've already check the bus connectors and they're ok, even I try with different connectors, but that didn't solve the problem. Thanks for answering
