10/17/2021 1:38 AM | |
Joined: 5/8/2021 Last visit: 10/30/2023 Posts: 1 Rating: (0) |
Could you help me too, i have the same problem but with tia portal v16. In log file i got this message: |ERROR |InitInstaller |(01) AddOn could not be loaded! Reason:An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569
Last edited by: Jen_Moderator at: 10/18/2021 10:39:49New subject after splitting |
10/19/2021 9:24 PM | |
Joined: 3/2/2016 Last visit: 4/2/2024 Posts: 72 Rating: (14) |
Hi Rezonator, First of all you should check that your O.S is compatible with TIA Portal V16 installation. You can check it in the delivery note of the product or using Compatibility Tool
