12/9/2021 11:04 AM | |
Joined: 10/11/2006 Last visit: 9/18/2024 Posts: 5906 Rating: (804)
Hello, please use V-Assistant to commission driver again when you use GSD. First do "Factory reset", then set the right telegram and functionality, and test drive with "Drive control panel. Then check settings in TO and controll TO,actualvelocity, when moving the drive with V-Assistant. When this is OK, use TO control panel. When you use HSP, there is an example: https://support.industry.siemens.com/cs/de/en/view/109780895 |
With best regards, |
