4/30/2025 7:01 PM | |
Joined: 7/11/2024 Last visit: 9/9/2025 Posts: 200 Rating:
Hi According to Siemens info: 6ES7516-3AN01-0AB0 > 6ES7516-3AN02-0AB0 > 6ES7516-3AP03-0AB0 As far as I know, when there are two jumps between successors, compatibility is not guaranteed. As you can read in the next FAQ, when the CPU is replaced with a successor you can leave the original one in the project but in this case I would contact Siemens: How do you find the right successor product if the existing product has already been discontinued? Good luck! |
If this post has been useful, don't forget to rate it!😊 |
5/2/2025 7:29 AM | |
Joined: 7/9/2015 Last visit: 8/29/2025 Posts: 4443 Rating:
Hi, ES7516-3AN01-0AB0 is compatible to newest model. But not ES7516-3AN00-0AB0 to newest - please check rules for replacement parts scenario: https://support.industry.siemens.com/cs/de/en/view/109815056/161012700811 Regards, Towome |
5/8/2025 8:54 AM | |
Joined: 6/19/2019 Last visit: 9/8/2025 Posts: 743 Rating:
Hello, Data sheet writes: So can't do with V15 anymore |
