6/30/2009 4:34 PM | |||||||
Joined: 4/5/2006 Last visit: 7/30/2025 Posts: 917 Rating:
Hi Pondax
>>> info from NOTIFY_8P help <<<<< Error explanation: At the initial call·the specified EV_ID was out of the permitted range·formal error in the ANY pointers SD_i·the maximum memory area length the CPU can transfer per SFB 31 has been exceeded Maybe you didn't connect in right way the EV_ID parameter... You developed your own FB by SCL or "compiling chart in chart"? If you did by SCL can you get more information in "PCS7 - Programmin Instruction for Blocks" manuallocated in PCS7 documentation here link from previuos tread
and from web support page
Hope can help Regards |
7/1/2009 7:04 PM | |
Posts: 2661 Rating:
When you compile the CFC are you getting any "Local Data" warnings? |
7/2/2009 11:04 AM | |
Hi Pondax; no says sorry, i say thanks to you to share your knowledge Regards |
