3/2/2023 12:31 AM | |
Joined: 9/9/2015 Last visit: 4/9/2025 Posts: 732 Rating:
Hi, Yes, you may export in process object view or copy and paste to excel. Go to Simatic Manager -> View-> Process Object View -> select your chart or plant hierarchy unit > go to "Block" tab > all block comments are here. Process Object View (POV) is similar with excel format, demonstrating all the function blocks, settings in table format with different columns on top. You may select a number of categories such as chart, blocks, parameters, signals, messages, etc for information editing. Hope this is helpful |
Please give me 5 stars Rating if my post is helpful for you. :) |
3/3/2023 6:54 AM | |
Joined: 5/3/2017 Last visit: 2/6/2025 Posts: 673 Rating:
Hi Mojtaba, The block comment is monolingual in the SIMATIC Manager. If it's required that the block comment is multilingual in the OS, entered the multilingual text in the text library of the OS. If you have to translate all text in PCS 7, see the application example Configuration of Texts and Languages in SIMATIC PCS 7, where is described which texts in PCS 7 can be edit multilingual. With regards |
