3/22/2021 5:08 AM | |
Joined: 9/13/2018 Last visit: 5/19/2025 Posts: 3 Rating:
Hi, In my Working Plant CPU 417-5H PN/DP (6ES7417-4HT14-0AB0) Secondary PLC Faulty. Primary PLC in Run mode (no issue) So we planned to replace new plc during plant shutdown (downtime 3 hours) i am already aware how to replace. But Existing part number 6ES7417-4HT14-0AB0 has been obsoleted. In siemens Market 6ES7 417-5HT06-0AB0 this latest part number only available. So my Query is 1. Can replace new version 6ES7 417-5HT06-0AB0 plc in only secondary PLC? 2. Or need to change both plc (Primary & Secondary PLC) with hardware configuration changes? 3. Any other caution required during replace both plc? <<<<<<<<Siemens Adviced PDF Copy also attached>>>>>> Thank you in advance AttachmentSiemens Advice for new PLC (From 6ES7417-4HT14-0AB0 to 6ES7 417-5HT06-0AB0).pdf (583 Downloads) |
