4/25/2013 2:53 PM | |
Joined: 7/7/2010 Last visit: 9/8/2025 Posts: 16066 Rating:
Once your project is migrated and hardware configured in TIA Portal, once the project is downloaded to the PLC, you should be able to go online. Until it is downloaded, you may need to submit a Support Requestto find alternatives. |
science guy |
4/25/2013 7:28 PM | |
What it sounds like you really wanted was a combo license for the portal software which allows you to run legacy S7 (5.x) as well as the newer TIA Portal software. Support Requestis the true expert and can help with all problems, big, small, and in between. We forum users like yourself are typically just end users who participate and exchange information and knowledge to help improve understanding of the hardware and software we either choose to use or are forced to use or are stuck with (depending on your perspective and frustrations at the moment). We do not typically tutor or teach, though at times it may appear we do. There are many manuals written in many languages covering a wide range of topics that describe the hardware and software. The best solution for you would be to submit your Support Requestand get the right license to match your needs. They can also help suggest the right license before you purchase or can find your best regional resource to help - depending on availability (which sounds like is very low). I hope you find these forums helpful. They have certainly helped me understand the hardware and software I am either being forced to use or choosing to use. |
science guy |
4/26/2013 7:00 AM | |
Posts: 41 Rating:
Many thanks Huggy I will try that. |
