6/18/2015 10:48 AM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello, Start to read here: STEP 7 From S5 to S7 - Siemens Below from page 20/23 there is an Appendix for migrate the components from S5 to S7 SIMATIC S5 to S7 Migration SIMATIC S5 to S7 Migration - Siemens For HSC if you want 1 Channel Counter for S7 is 6ES7 350-1AH03 (FM 350-1) it should work FM 350-1 Counter module - Siemens At the moment what software you have? STEP 5,STEP7 "Classic" ,STEP7 TIA Portal, Etc...
Last edited by: Ste39 at: 6/18/2015 10:55:15 AMLast edited by: Ste39 at: 6/18/2015 11:09:28 AM |
6/18/2015 12:19 PM | |
Joined: 11/21/2007 Last visit: 7/25/2025 Posts: 2326 Rating:
Hello Besides what Ste39 has already suggested, The CPU 313C has Onboard 3 FAST COUNTERS (30 KHZ), 24V DC. You can check the possibility of using the same if the Encoder Type and Max Frequency are within this limit. Here is the link for the Manual : https://support.industry.siemens.com/cs/in/en/view/12429336/30107678219 Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
2 thankful Users |
6/18/2015 2:47 PM | |
Hello M.Engineer Vietnam, I have some doubt with the conversion from OPUS CP5000 to OP77A, you have the original project? Is this type? I don't know for this OPUS 5: OPUS 5 an Siemens S5 - IBP GmbH Thread for standard OP5: programming OP 5 using COMTEXT software - Entries - Forum ... Back Up OP5 Coros - Entries - Forum - Industry Support - Siemens
6/18/2015 2:48 PM | |
Posts: 1058 Rating:
Hello M.Engineer Vietnam, additionally to the information given by Ste39 and Navnag, there is also an application example available for a migration from S5 to S7: Migration Guide: SIMATIC S5 to SIMATIC S7-1500 Although this migration example uses S7 1500, most of it appies to your situation too. regards |
2 thankful Users |
6/19/2015 5:52 AM | |
Posts: 5 Rating:
Thanks a lot all friend, I will try |
6/19/2015 5:55 AM | |
Posts: 5 Rating:
HMI OPUS 5 is type: OPUS 5 an Siemens S5 - IBP GmbH
