8/25/2010 11:52 AM | |
Joined: 8/25/2005 Last visit: 5/30/2025 Posts: 1162 Rating:
Hello hasses, it would me much easier to answer your question if we could get more information.
Please tell us more about your configuration and the background of your question. Hope then it will be easier to get a solution. Good luck Sabine |
8/25/2010 8:09 PM | |
Posts: 5 Rating:
EDS have the HA7E a RS232 to 1-Wire interface designed to provide an ASCII command set for RS232 serial hosts that need to accommodate Dallas Semiconductor iButton and 1-Wire devices. So you could use the CM1241 RS232 & HA7E to communicate with the DS18S20 http://www.embeddeddatasystems.com/HA7E--ASCII-1-Wire-Host-Adapter_p_21.html Avaiable from UK |
1/2/2012 7:26 PM | |
Posts: 1 Rating:
I do have a HA7E and a CM1241. I'm only getting fault code 7000 when trying to send a command to the HA7E. Do anyone have this up running ? |
4/28/2012 11:04 PM | |
Joined: 3/11/2007 Last visit: 6/6/2025 Posts: 226 Rating:
Alternatively you can build this simple electronic circuit http://www.electro-tech-online.com/electronic-projects/87533-one-wire-temperature-sensor-ds1820-pc-interface.html |
