1/20/2023 1:41 PM | |
Joined: 8/3/2009 Last visit: 9/3/2025 Posts: 16322 Rating:
Hello Cflex Check the Manual for Backup/Restore possibilities: https://support.industry.siemens.com/cs/ww/en/view/21084916/3369195147 -> If you have the WinCC flexible project you can open and migrte it to your new Version then you can do a OS update and load the PAnel again. But if you only want to replace it without any changes I would do Backup/Restore Bye Murof |
Last edited by: Murof at: 01/20/2023 13:41:57If this Information really helps, you could use the Rate function |
1/25/2023 12:39 PM | |
Joined: 10/30/2019 Last visit: 8/4/2024 Posts: 4 Rating:
will any MMC card work or is this a special card i need for this? |
1/31/2023 1:28 PM | |
Hello I think this one should work: https://mall.industry.siemens.com/mall/en/de/Catalog/Product/6AV6671-1CB00-0AX2 But also every other card should work theoretically but do not use a too big one Bye Murof |
