10/13/2021 3:57 AM | |
Joined: 6/3/2021 Last visit: 1/19/2022 Posts: 4 Rating:
Hi, I am using a S7-1200 and activated the "global security settings for certificate manager" and generated a "TLS" and a "webserver" certificate in TIA Portal. Then I activated the webserver and only allowed access via HTTPS. How can I make the webserver use the generated certificates and not the default one? I found out in CertificateHandlingTIAPortal_V1_0_en.pdf on page 21 that there should be a security tab in the Webserver settings where you are supposed to select the certificate but this tab is not displayed for me. Best Regards Xhenet |
Last edited by: XhenetHPI at: 10/13/2021 03:58:52Last edited by: Jen_Moderator at: 10/13/2021 09:29:57Optimized link. |
10/13/2021 11:11 PM | |
Joined: 7/7/2010 Last visit: 9/12/2025 Posts: 16094 Rating:
What firmware is installed in your S7-1200? The very latest TIA Portal and S7-1200 firmware might be required to do what you want.
science guy |
10/14/2021 4:12 PM | |
I am using the 1212C AC/DC/Rly 6ES7 212-1BE40-0XB0 with firmware V4.4 and TIA Portal V16 |
4/1/2022 6:09 PM | |
Try FW 4.5 Read the change log here: https://support.industry.siemens.com/cs/document/109793280
science guy |
