4/21/2023 8:33 AM | |
Joined: 7/5/2021 Last visit: 8/19/2024 Posts: 1 Rating:
Any updates on this issue? I have a similar problem: The interlock text are not showing on WinCC runtime. -Text 0 and Text 1 were configured in the AS -AS Compile and Download done -OS full compile with memory reset done the Text only show in the detailed view home page and not on the main home page (see screenshot) ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/21/2023 10:30:19New subject after splitting |
4/27/2023 11:58 AM | |
Joined: 1/11/2019 Last visit: 8/14/2025 Posts: 899 Rating:
Can you show us a screenshot in you CFC interlock block properties? Go to I/O, look for the Column " Identifier" and "OS additional Text", did you really program the text on? And can you do a OS Full Compilation after the check? It should show. If not, can you let us know your Installed Software? Look for AS-OS installation. Which PCS 7 are you using? Look for the software update SoftwareUpdates |
