2/20/2025 2:05 PM | |
Joined: 2/1/2010 Last visit: 9/12/2025 Posts: 212 Rating:
Assuming PCS7 OS Server/Client architecture and not just single OS, you need to install and license Logic Matrix Viewer on each client, not just the server. Is this the problem, or you are testing only from OS server now? |
If my post helped you, please rate. Thanks. |
2/25/2025 1:34 PM | |
Are you sure that is a Logic Matrix and not a Safety Matrix? They are different products. It was hard to notice at first, but your matrix header is yellow typically indicating Safety Matrix. You also seem to use the words interchangeable in your message but it is not the case. In that case you need to have Safety Matrix viewer licenses. You may have both in the same project but they are not the same license. |
2/26/2025 11:16 AM | |
Joined: 6/19/2018 Last visit: 7/4/2025 Posts: 30 Rating:
Hi, i atraached a file with the crops of my project. Maybe i was wrong talking about Logic Matrix and really is Safety Matrix. My mistake. In the other hand, i have licenses for Safety Matrix Edit and Viewer. And licenses for F system too. Regards. AttachmentSafety Matrix.pdf (194 Downloads) |
2/26/2025 5:40 PM | |
Do you have all the @PG_F_xxxx.pdl files in your OS project GraCS folder? If not, then faceplates won't be able to work. The 6.3 manual dropped the install information, but it used to be there in the 6.2 Safety Matrix manual. Make sure those files are in there, if not you need to run OS project editor on each OS project where you want faceplates (OS server, OS client(s)) and select them from the basic data tab to get them in your project(s). |
