6/29/2009 1:23 PM | |
Joined: 10/7/2005 Last visit: 9/8/2025 Posts: 3049 Rating:
Dear olo_p you really already answered your own question. Data record routing is a must for PDM usage if you want to"route"through a PLC and only S7-400 (as of newer firmware) support this. Have a look at this link for more (which also points you to alternatives that do not require data record routing through the CPU): What is the difference between Routing and Data Record Routing? I hope this helps |
6/29/2009 2:27 PM | |
Posts: 49 Rating:
Hi, Please find the link, It gives a complete list of modules which are support"S7 routing function" What are the requirements for using the S7 routing function and which modules can you implement? Hope this information helps!! Regards, Enigma |
6/30/2009 6:58 AM | |
Crikey!, I stand corrected and was not aware that Siemens had (behind my back) already enabled Data Set (Record) routing for atthe 319 and now also for the latest 315F(most interestingly, as of firmware 3.0 the new 300 CPU'swill allow online montoring of 2 Blocks at the same time amongst soem other long overdue improvements). Your understanding isright too by the way, Data Set routing and Data Record routing are two different terms for the same functionality. |
Cheers |
6/30/2009 8:48 AM | |
Posts: 19 Rating:
why did you write 315F?? It concerns also the newest base version 315-2DPwith order number 6ES7315-2AH14-0AB0 with double work memory. regards Olo |
6/30/2009 9:21 AM | |
because I forgot to put the "()" around the "F" |
Cheers |
6/30/2009 10:10 AM | |
Posts: 19 Rating:
ok. All clear best regards Olo |
6/30/2009 11:36 AM | |
Posts: 49 Rating:
Hi Olo, Please have a look at this FAQ. What are the requirements for using SIMATIC PDM Data Record Routing? This FAQ has some more links to important info. If you find some detailed info about how to usePDM with S7300, kindly post it. Regards, Enigma |
