9/14/2023 10:53 AM | |
Joined: 3/14/2008 Last visit: 9/8/2025 Posts: 2216 Rating:
Hi, Can you open the "Module driver" tab and report a printscreen? |
9/14/2023 12:35 PM | |
Posts: 15 Rating:
I sent you the photo |
9/14/2023 4:41 PM | |
Posts: 15 Rating:
My connection is established correctly |
9/14/2023 4:55 PM | |
Hi, So you still have the problem? I have seen this error before. Something went wrong with the installation of the classic library V7.1 SP3 Upd4. There is a special order to install the old library over the APL. You can try to reinstall the APL library only. Is this your case as well? |
Last edited by: Oreca at: 09/14/2023 16:55:38If I could help you, you can use the RATE button. Thank you. |
9/14/2023 7:49 PM | |
Hi, Please install the APL library now. The manual describes that after installing the old library, you have to install APL over them. |
9/14/2023 8:03 PM | |
Posts: 15 Rating:
Which version of the library should I install? Do you mean that I should install all new libraries for pcs7 V9 SP1 version? |
9/14/2023 8:05 PM | |
Install the APL library V9.1 SP1 from the software media |
