5/31/2008 6:52 AM | |
Posts: 27 Rating:
Hi, Iam using CFC for Fail safe programming. When even i compile my F program on My Laptop i get the attached progrmming error message. But when i compile the same program on other PC the compilation is proper.I have also attached the installed softwares on my Pc. erroe1.txt : contails the error after compilation. installed.txt:contails the installed software. error.txt: contails the error after i delete the cfc charts from simatic manager. Regards, Sam AttachmentAllErrors.zip (268 Downloads) |
5/31/2008 8:31 AM | |
Posts: 2661 Rating:
Please post installed SW from both machines. |
5/31/2008 9:16 AM | |
Posts: 27 Rating:
Hi , Attached installed SW of the second PC. AttachmentCDC.zip (296 Downloads) |
6/1/2008 6:13 PM | |
Posts: 2661 Rating:
Sam: Check the F library version used in your project: 1. Click on CPU. 2. In Options menu on top, Edit Safety Program. One of your machines has both F Lib V1_2 and V1_3. My suspicion is the blocks got mixed up. If you do want to migrate to F Lib V1_3, follow the steps described in the manual(Use Case 4): S7 F/FH Systems - Configuring and Programming
