10/31/2014 5:51 AM | |
Joined: 11/21/2007 Last visit: 7/25/2025 Posts: 2326 Rating:
Hello dendhondt I have seen such behaviour in S5 timers. The cause in not really clear. However you need to just force the timer to reset ( Add a Timer reset command with a manual trigger ) . Once reset , after removal of Reset, the timer will work normally. a Simple Power ON/OFF will also usually bring things back to normal. Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
