11/15/2021 6:35 AM | |
Posts: 13 Rating:
hello sir we have 10 cnc machines which all of their default languages have been set on German. this issue is boring us. I knew the instruction you explained but when I change the number of dm9003 to 1 or 2 nothing is happened. every day we, after starting up the machines by touching CTRL+L, change the language to English. please help us to set English as default. regards
Last edited by: Shahab1353 at: 11/15/2021 06:37:14Last edited by: Jen_Moderator at: 11/15/2021 12:12:45New subject after splitting |
11/15/2021 4:08 PM | |
Joined: 10/17/2007 Last visit: 9/15/2025 Posts: 4451 Rating:
I think you read the topic "810D shopmill change language" --you see the members discussion . and you see " Many thanks MS_LAZZ, it is now running in English." one thing i need correct it --it is not call DM9003 instead it should be MD9003, MD=Machine data. make sure you search in "Start up --Machine Data--Display MD--MD9003" after change making power off and on. If do the correct MD but still not working , send feedback to here and inform what kind of MMC or PCU you have (Siemens label on the back of MMC case). and contact OEM
If you like my comments please |
11/17/2021 6:06 AM | |
Posts: 13 Rating:
11/17/2021 5:21 PM | |
Posts: 13 Rating:
Hello again "Pcu20" is the thing I see when the machines are going to start. Best regards |
11/23/2021 6:31 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8171 Rating:
New question published by Shahab1353 is split to a separate thread with the subject NC Programming issue with TRANSMIT and TRAYOL . Best regards |
