10/31/2021 11:51 AM | |
Posts: 1 Rating:
I have a sinumerik 850m as well, the display comes up for a while and starts blinking, how to make the display start working again? We also replaced the battery recently ------------------------------------------------------------------------------------------ |
11/3/2021 8:55 PM | |
Joined: 10/17/2007 Last visit: 9/9/2025 Posts: 4443 Rating:
Even you did not post picture, I guess you have your CRT display blink? try to adjust Synchronize Potentiometer--open the CRT back case cover (shut off power for safety), even you can see that Potentiometer from the top of your CRT cover from the grill holes , but I suggest you open the back caver. locate the position then power on, use insulated screwdriver turning slowly CW or CCW , this one fix by wax after adjusting waxing it again If you cannot find where ? send the picture from the top of CRT --I will point to you Good Luck and please feed back here
