11/30/2012 10:18 PM | |
Joined: 7/7/2010 Last visit: 9/8/2025 Posts: 16067 Rating:
Add a new tag after Static_1. You will then see the offset. You can also create 11 individual DWord tags and the offsets for each will appear. The offsets from _within_ the array will not be shown. If you create a structure called Static_1, then create 11 DWords, named Static_1_0, Static_1_1, ... , Static_1_10, and all offsets would then appear if I recall correctly. Structures and individual tags give you offsets. Arrays do not. Perhaps in V12 that will be changed? Maybe you can submit a Support Requestasking for a work-around? |
science guy |
11/30/2012 10:45 PM | |
Joined: 1/17/2006 Last visit: 7/14/2025 Posts: 554 Rating:
huggy_d1, Thank you for your help. I've already sent this issue to Siemens support as you advised me. Best regards, Berg |
