8/2/2024 9:19 AM | |
Joined: 6/13/2019 Last visit: 5/21/2025 Posts: 2 Rating:
The "new" TIA Admin is actually trash. The UI is clunky, there is no clear indication of install progress, installs happen silently (and fail silently) & most times I have to install any updates manually. This morning, I opened TIA Admin & it updated itself - no indication of anything, the icon just disappeared in the task bar when hovering over it after a while. Rebooted & "localhost refused to connect." Downloaded the latest version from support - install - reboot - wait for services to start - double click TIA Admin icon - same issue. The worst update client I've ever used hands down. While the older TIA admin also had it's issues - at least I could use it. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 08/05/2024 08:15:33New subject after splitting |
12/6/2024 4:17 PM | |
Joined: 4/27/2015 Last visit: 7/2/2025 Posts: 11 Rating:
Figured it out! https://support.industry.siemens.com/cs/ww/en/view/109976735/en This is the answer. Would be nice if TIA Administrator would check for WMIC and tell you it isn't there rather than just not working. |
3 thankful Users |
