11/21/2012 8:23 AM | |
Joined: 1/4/2011 Last visit: 7/9/2024 Posts: 9 Rating:
Wich best sistem for timer on-off with s7-1200 ? Are there library function for this timer ? Tnx Pich
11/21/2012 8:36 AM | |
Joined: 4/22/2010 Last visit: 3/31/2025 Posts: 5697 Rating:
Hello, If you mean a timer to blink a lamp, you can use the Clock memory bits. Activate them in the CPU properties and you have standard clockbits. How can you avoid overwriting the flags that are allocated for system and clock memory bits in the user program? If you need different times you can use 2 on delay timers to do the job. Regards, Marcjan |
Problem solved? |
