11/16/2012 7:22 AM | |
Posts: 37 Rating:
Hi I want connect wincc in tia portal v11 with SQL server 2005 . but I am not find " OLE DB Provider " in tia portal v11. can you help me Thanks
11/19/2012 3:41 PM | |
Posts: 3037 Rating:
Hello, You can use this excel appllikationin thelink for WinCC V11. Export of WinCC / CAS Archive Data using the WinCC OLE DB Provider https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=41583856907&Language=en-US&TopicId=12280927115 Tweety |
