11/20/2024 1:14 PM | |
Joined: 8/3/2009 Last visit: 9/5/2025 Posts: 16349 Rating:
Hello you can use Control Tags or the programming API functions (C Script) or the Control in Runtime to save new values: It should be all explained in the Help System with examples: https://support.industry.siemens.com/cs/ww/en/view/109815056/109072132619 Bye Murof |
12/9/2024 2:34 PM | |
Joined: 11/11/2023 Last visit: 8/7/2025 Posts: 37 Rating:
How do I access API functions?
Something else new How can I create an ordered list table with lists of these recipes by name? I only need to search by name |
12/12/2024 10:22 AM | |
Hello AutoGen_2379672 Check in your TIA Portal help and search for: "Example: Recipe functions" There you can find an example how you would work with the Recipe C Script interface. A reference to the UA functions you can find here: https://support.industry.siemens.com/cs/de/de/view/109813306/140807427339 And you can also use with this queries to read out all datasets Bye Murof |
