(0)| 1/6/2012 9:08 AM | |
Joined: 4/14/2010 Last visit: 6/26/2025 Posts: 525 Rating:
Greeting, Could you explain how can i configure the FB 432 to get the date for CPU 400 Diagnostic..??? please describe the parameter for FB 432 see attached.. Can i programe this in STL or CFC package require..??? Thanks Regard AttachmentDesktop.zip (291 Downloads) |
Last edited by: CS Moderator at: 1/6/2012 11:43 AMnew subject after splitting from /tf/WW/en/Posts/67560#top Last edited by: Sarfraz Bhatti at: 1/6/2012 9:23 AMMS |
| 1/10/2012 9:08 AM | |
Joined: 10/10/2005 Last visit: 1/29/2025 Posts: 1940 Rating:
Hello, I'm not understand. Do you use SIMODRIVE? There is also the using of a FB432. Please see in this case the FAQ in refer to this link: http://support.automation.siemens.com/WW/view/de/19364531 With best regards |
| 1/10/2012 9:19 AM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating:
Thread closed, because question is already discussed in the following thread System Diagnostic V4.0. Best regards O_Moderator |
