7/20/2013 11:44 AM | |
Posts: 18 Rating:
i tried to check the addresses and change it many times in DIP Switches Physical and in HW Configuration and redwonload but the resuslt was the same,,, and the same in bus connector switches make it ONand OFF depends on the node loacation in network
the nodes is show rightly in Accessible nodes for CPU and Two IMswith assigned addresses So, i doubt in some paramters should be assigned in HW like DP interupt and Operation at preset<> Actual Configuration and may be somthings else u will found Screen Shot for HWC Diagnose and ET200 AttachmentNew Folder.zip (380 Downloads) |
