9/13/2017 4:47 AM | |
Posts: 297 Rating: (41) |
Just a guess, but shouldn't the NC lines use: /dev/ext/1 instead of /ext/dev/1? HTH, SteveA |
9/13/2017 8:56 AM | |
Posts: 10 Rating: (1) |
Hi, Out of my point of view the login-information and the password is missing in your "extdev.ini". As I remember these information are mandatory. Here is a sample of my former investigations with "OK" and "NG" settings. (The difference is always the "name" of the external PC. Acces was only possible by IP-address and not by name). It's a long time ago, perhaps it's helpful... ; Sample of configuration file /oem/sinumerik/nck/extdev.ini and /user/sinumerik/nck/extdev.ini: ; Will apply for NC program comands EXTOPEN/WRITE/EXTCLOSE and ISOOPEN/ISOPRINT/ISOCLOSE [ExternalDevices] ; tested NG ; tested OK ; tested NG |
9/13/2017 2:59 PM | |
Posts: 3 Rating: (1) |
yes, on the NC side we were backwards. thank-you for pointing that out! |
