4/8/2012 9:39 AM | |
Joined: 12/1/2009 Last visit: 5/22/2024 Posts: 672 Rating: (147) |
Hi, I do not use the OB's while, do to any reason, they do not get called sometimes correctly. Call it a "bug" or a "feature", as you like. What's the use of something which does not work properly? So for meit's a BUG. The developers should fix this issue.If they cannotthe OB's should get removed. I use the SFC51 function instead and it works fine with me, allways. Regards. Everybody has the same problem. Have a look at this thread: /tf/WW/en/Posts/50068#top |
Last edited by: TIBI68 at: 4/8/2012 9:45 AMGive us your feedback and show us your respect! |
