7/16/2013 5:46 PM | |
Posts: 33 Rating:
Hi, I cant add any new ActiveX Controls in my controls panel. I do it like in :https://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&objId=40614405&nodeid0=10805577&load=content&lang=en&siteid=cseus&aktprim=0&objaction=csview&extranet=standard&viewreg=WW but nothing happens... I still have the old one set of controls without new. WinCC 7 SP 3. I add that I remeber that did it once in different project and it worked.
7/16/2013 6:08 PM | |
Posts: 378 Rating:
Hello white_snoopy , Please tell us your specific problem. Which activex control is you are going to add to wincc? Is your activex component is listed under Available OCX Controls? If not listed first on command prompt Regsvr32 path_of_your_ocx\file_name.ocx Regards |
7/16/2013 6:28 PM | |
Posts: 378 Rating:
Hello again. Try uninstall all wincc softwares then install and dont forget to restart your PC after uninstalling. Regards |
7/16/2013 6:36 PM | |
Joined: 10/3/2010 Last visit: 7/5/2024 Posts: 1556 Rating:
Off course you want to avoid that but regarding your issue, it's seems like an installation error. |
B r g d s , |
7/17/2013 7:13 AM | |
No real fast way, uninstall procedure is described in manual located in your installation directory under "Install_and_Release-Notes\english\InstallNotes.pdf", chapter 6. In case you don't have it right now, I attached the chapter but you probably know it. What you can try is to install a newer update (latest is Update 5 for V7 SP3). If you're lucky, it could fix the problem. Attachment6-Uninstall WinCC.pdf (96 Downloads) |
7/24/2013 1:04 AM | |
Posts: 33 Rating:
I've reinstall WinCC and it didn't fix the problem. |
7/24/2013 7:23 AM | |
B r g d s , |
