4/18/2012 8:34 AM | |
Posts: 10 Rating:
4/18/2012 8:44 AM | |
Joined: 12/1/2009 Last visit: 6/7/2024 Posts: 672 Rating:
Hi Distazo, you can try to remove the battery and put it back. A bad connection can prevent the PG from startup. Regards. |
Give us your feedback and show us your respect! |
4/18/2012 9:38 AM | |
Posts: 8946 Rating:
Try also to test your battery with the Field-PG Panel. AttachmentFieldPGPanelV21.zip (629 Downloads) |
4/20/2012 5:10 AM | |
Posts: 10 Rating:
Thanks TIB168 I did as per your advise and the PG is OK |
4/20/2012 3:51 PM | |
Posts: 947 Rating:
in additional: for field Pg m2 and also other version Field Pg should install last actual version BIOS |
5/8/2014 9:40 AM | |
Joined: 3/2/2007 Last visit: 7/15/2024 Posts: 932 Rating:
why BIOS has control over the battery? how? |
... thank you ... |
5/9/2014 9:40 PM | |
Posts: 8946 Rating:
Charging is mostly controlled by BIOS. |
