2/8/2011 2:35 PM | |
Posts: 2964 Rating: (482)
Hello.... * Standard Serial Cable...is enough for upload and download. Pin connection of serial cable with 9-pin or a 25pin female connectors on both ends. Three wires requried for data transmission: Ground-Ground Transmit-Receive Receive-Transmit 9Pin 9Pin Pin 5------- Pin 5 Groung-Ground Pin 3 ------- Pin 2 Transmit-Receive Pin 7 ------- Pin8 RTS-CTS Pin 6 ------- Pin 4 DSR-DTR Pin 2 ------- Pin 3 Recive-Transmit Pin 8 ------- Pin7 CTS-RTS Pin 4 -------Pin 6 DTR-DSR 25Pin 25Pin Pin 7 ------- Pin7 Groung-Ground Pin 2 ------- Pin3 Transmit-Receive Pin 4 ------- Pin 5RTS-CTS Pin 6 ------- Pin 20 DSR-DTR Pin 3 ------- Pin 2 Recive-Transmit Pin 5 ------- Pin 4 CTS-RTS Pin 20 ------ Pin 6 DTR-DSR I am attaching you the document of how to upload/reload the backup...Check it out.... RS232 cable is sufficent for connecting to Step5 Where I can find text file with error and messages (6000.., 7000..)? check this link..... http://support.automation.siemens.com/WW/view/en/21901877 Regards, Ekalavya Attachment810_820 reload.pdf (1020 Downloads) |
2/9/2011 11:09 AM | |
Hello.... Yes you can download PLC program PCP through PCIN..... There is no specific document in 810T but you can find the information in Simodrive 611A document.... link attached for the reference... https://www.automation.siemens.com/doconweb/content.asp?item=12807&cd=sinumerik_simodrive_04_2010_e&scope=all Regards, Ekalavya |
2/9/2011 11:56 AM | |
Posts: 259 Rating: (5) |
I know that i need this cable (in attachment), but what softwear i need to download all paramteres.
Attachmentcable-real for 611a.pdf (855 Downloads) |
2/9/2011 12:27 PM | |
Hi... You can use WINPCIN / PCIN software for downloading all the parameters.... Check this PDF for the information.... Regards, Ekalavya AttachmentSinumerik 810_820.pdf (849 Downloads) |
