10/14/2019 8:46 AM | |
Joined: 9/9/2015 Last visit: 7/24/2024 Posts: 727 Rating:
Dear golovkin, The Block comment that you insert in the block properties will be transferred to text library after os compilation. Then you can edit it in text library in other languages columns. By default, all the remaining languages will follow the default one in English column. You may edit the German col/ the rest of the language. For Chinese, you will need PCS 7 Asia version installed. To switch language, you can change it in WinCC Runtime. Hope it helps. |
Please give me 5 stars Rating if my post is helpful for you. :) |
10/14/2019 8:57 AM | |
Joined: 5/3/2017 Last visit: 5/21/2024 Posts: 673 Rating:
as addition the link to the Siemens document with the statement from JazTai |
