12/13/2010 6:54 AM | |
Posts: 46 Rating:
OK, here it is. Unfortunatelyinstallation packet is not implemented yet, so you have to install it manually. - !firstyou should have.Net Framework 3.5 or later installed on your system! -extract archive to the place of your choice -on XP -double click on install.cmd -on Windows 7 - run cmd.exe as administrator, change work directory to the place where you extracted files (cd c:\ModbusTCPtoRTU)and runinstall.cmd -go to Control panel -> Administrative Tools -> Services and start ModbusTCPtoRTU service -go to Control panel -> Administrative Tools -> Events and look for event like this: "Reading config result: |LICENSE:ERR - request key code for product ID: xxxxxxxxxxxxxxxxxxxxxxxxx= ||TCP:OK||RTU:OK|" -send me xxxxxxxxxxxxxxxxxxxxxxxxx= in private message -i'll send you fully functionallicense code (for free in exchange for testing) -put license code in cfg.xml -adopt other parameters in cfg.xml to your needs -start service again (you can make it autostarting in service properties) -test it with WinCC or other Modbus TCP client If you'll notice any bugs - write to me i'll try to fix it. AttachmentModbusTCPtoRTU.zip (863 Downloads) |
1/17/2011 12:45 PM | |
Posts: 46 Rating:
I wonder why people who downloaded file do not ask for free of charge, fully functional license key... |
5/25/2016 9:23 PM | |
Posts: 60 Rating:
hello does anyone know where I can get the key now??? |
