3/31/2021 11:48 AM | |
Joined: 3/3/2021 Last visit: 2/16/2022 Posts: 1 Rating: (0) |
Hi Divej93, I have a problem in integrating a Sick Encoder in TIA Portal. May be you can help me. My encoder is (18*12) resolution i.e. multiturn Resolution per revolution = 2^18 =262144 No of revolutions = 2^12 = 4096. I did everything which you mentioned in the thread including enabling of the scaling function. My problem is when I am rotating the encoder for one revolution, it should show the position value = 262144 after one revolution. But it is showing a totally different value. Can you help me, why is it so. You also mentioned you checked your encoder by homing it. How can I do Homing of Encoder in TIA Portal. With Regards, Gaurav ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/31/2021 13:21:41New subject after splitting |
