10/29/2010 1:56 PM | |
Posts: 1 Rating: (0) |
Hello I need some solution of generate report in WinCC 2008 flexible, report must contains 160 records of 7 value per shift I'm not be able to find same solution in standard WinCC options maybe in WinCC 2008 its "report designer" like a in WinCC 7 or its some function to edit "Print Alarm" in report tools i hope its not necessary to write some VB scripts :) please help becouse i not have any ideas for solved this problem best regards Splitted from Standard report script. Attachmentreport.pdf (213 Downloads) |
Last edited by: O_Moderator at: 11/4/2010 2:16 PMnew subject after splitting Last edited by: L.g. at: 10/29/2010 2:59 PMLast edited by: L.g. at: 10/29/2010 2:59 PM |
