4/19/2010 9:08 AM | |
Posts: 661 Rating: (123) |
perhaps this helps ? /tf/WW/en/Posts/32562 |
4/23/2010 11:20 AM | |
Hello lei7o, so far i could not find a solution. I could create a decimal->BCD converter for 2 digits (0-99). But with this program it´s only possible to count up, not backwards. But there are also 7-segment displays available which have a 0-10V or 4-20mA input. http://www.laurels.com/process-meters.htm If you use the AM2 AQ module, you could convert the decimal value into an analog value 0-1000 to address the display. Attachmentdecimal to BCD Converter_8bit_count_up.zip (311 Downloads) |
4/23/2010 1:40 PM | |
Yeeha, got it. Attachmentdecimal to BCD converter_8bit_count_down.zip (327 Downloads) |
4/23/2010 8:10 PM | |
Posts: 19 Rating: (1) |
Hello Just another idea for down counting, I hope can be usefull, of course not decimal to bcd conversion included.
Attachmentdown counter.zip (375 Downloads) |
