6/15/2023 8:39 AM | |
Joined: 6/15/2023 Last visit: 6/15/2023 Posts: 1 Rating:
Dear all I have the same mentioned issue and i don't know how to check fault value in r2124, how can i find (r2124) ? Please help for urgent case. many thanks in advance . Best Regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/28/2023 10:23:21New subject after splitting |
6/15/2023 10:04 AM | |
Joined: 5/24/2016 Last visit: 8/8/2024 Posts: 346 Rating:
Hello. So r2124 would be in the drive parameter. In your case it only shows that the problem exist in SERVO 3.3.4 (4) So i have attached a .Zip file with picture that show pictures of the buttons i reference to below.
Press Menu Select - Then Setup - Then Mach. Data - Then Drive Parameter (or Drive MD depending on Operate Version) / Then on the top look at the ID data, and then by using the Axis + or Axis - Soft key on the upper right part of the screen look for the SERVO 3.3.4 (4) ID in front of this will also be the axis Then go down the list to r2124 and your data should be there. Best Regards Riddersholm AttachmentButton Pictures.zip (338 Downloads) |
