1/10/2011 6:08 AM | |
Posts: 2964 Rating:
Hello Deep, You need to really check after doing the LEC test.... result cannot be judged.... I am attaching you the PDF doc of 802d LEC.... Check it out.... Regards, Ekalavya AttachmentLEC_802d.pdf (344 Downloads) |
2 thankful Users |
1/11/2011 10:56 AM | |
Joined: 6/7/2010 Last visit: 7/9/2024 Posts: 571 Rating:
Yes Deep , accuracy level will be improved ,check it............. |
Regards, |
1/16/2011 8:01 AM | |
Posts: 2964 Rating:
Hello Experts, Is the attached procedure same for 840D. If not, can you attached the procedure for 840D, DE, Di. Thanks in advance. DEEP. Hi.... Check out this link /tf/WW/en/Posts/44986#top Regards, Ekalavya |
