1/1/2017 7:19 AM | |
Joined: 5/8/2016 Last visit: 2/15/2024 Posts: 167 Rating: (13) |
hey Am facing this problem when installing wincc scada please help me to solve this the setup stops responding in this microsoft kb2670838 and takes along time and doesn't respond
Last edited by: CS Moderator at: 1/1/2017 9:16:09 PMNew subject after splitting A lot of potential remains |
1/2/2017 7:09 AM | |
Joined: 7/20/2015 Last visit: 4/23/2024 Posts: 153 Rating: (27) |
Hello elctro hamad You can install separately this file from below link and again install Wincc 7.3 |
Last edited by: Sandeep Bakoliya at: 1/2/2017 7:17:22 AMIf I could help you, you can use the RATE button. Thank you. Regards |
1/2/2017 1:55 PM | |
Joined: 10/10/2014 Last visit: 4/18/2024 Posts: 1725 Rating: (209) |
Hi elctro hamad, the best and fastest way is to open a service request for siemens support https://support.industry.siemens.com/cs/start?lc=de-WW Best regards schufri |
1/4/2017 6:19 AM | |
thanks for all of you i will try to install it separately and i will give you afeedback |
1/8/2017 12:43 PM | |
Joined: 5/7/2016 Last visit: 4/9/2023 Posts: 2 Rating: (0) |
Hi hamad, I'm facing the same exact problem , if you solved the problem please share me the solution. Best Regards |
