9/26/2016 4:56 PM | |
Joined: 11/14/2008 Last visit: 5/6/2024 Posts: 504 Rating: (22) |
Hi Yash_Shekar, Please check page 79 in this document In your case it would be possible because only third number has changed between both firmware versions |
9/27/2016 9:30 AM | |
Joined: 7/9/2015 Last visit: 10/9/2024 Posts: 3966 Rating: (591) |
Hi, please check the following Link: Operating system updates V6 CPU412-5H PN/DP, CPU414-5H PN/DP, CPU416-5H PN/DP, CPU417-5H PN/DPFirmware update in RUN: Regards, Towome |
9/27/2016 2:05 PM | |
Posts: 17 Rating: (0) |
Thanku OmegaProjects for ur reply. From the document i understood that we can update the OS firmware in Run mode by stopping one CPU.
Also, the document says to restart the CPU at the end. Should we restarts the CPUs one after the other? or restart both at once? |
Last edited by: Yash_Shekar at: 9/27/2016 2:25:48 PMLast edited by: Yash_Shekar at: 9/27/2016 2:49:32 PM |
9/27/2016 2:07 PM | |
Thank you Towome for ur reply. Can we update firmware from V6.0.1 to V6.0.6 in one shot ? Or we should go from V6.0.1 to V6.02 and then from V6.0.2 to V6.0.3 so on till V6.0.6 ? |
9/29/2016 10:00 AM | |
Joined: 6/14/2006 Last visit: 6/17/2024 Posts: 301 Rating: (60) |
No you do not have to do any changes upfront. |
9/29/2016 1:20 PM | |
Thank you so much :-) |
