9/19/2008 7:41 AM | |
Posts: 1064 Rating: (72) |
/tf/WW/en/Posts/21782#top Check out this link it might be what you want look at this link if you want to upgrade the s5 cards to s7 S5-S7 Conversion help |
9/19/2008 5:37 PM | ||||||||||||||||
Posts: 487 Rating: (45) |
You can keep the modules in an expansion rack using the following
Another way is to use change the modules but still use the front connectors with S7 cards. This link below has more info. S5 S7_Adapter_Eng_V3_0.PDF |
