2/13/2010 6:05 PM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181)
Hello, So, to put your issue in SIMOVERT MASTERDRIVES conference is not useful. But anyway look at How do you configure connection of the PT100 to the analog input module SM 331 AI 8x12BIT? and compare with your settings. Also did you check what does say Diagnostic buffer in CPU? Best regards, Hristo Mihalev |
2/14/2010 8:40 PM | |
Joined: 4/24/2009 Last visit: 2/19/2024 Posts: 2683 Rating: (135) |
Thread closed, because question is already published in the following thread SF fault in Remote IO module. Best regards O_Moderator |
