2/8/2011 1:06 PM | |
Posts: 11 Rating: (0) |
Dear Sir,I am new to SIEMENS.I want to use sfc 5 for the diagonistic of DP slave.What values should i use in input parameters of the block.The hardware configuration is attached.I want to know the diagonistic adress of my IM.In my case 3FFC.Any example will be appreciated.Thanks in advance Splitted from Gettign logical address with SFC5. |
Last edited by: O_Moderator at: 2/8/2011 1:27 PMLast edited by: O_Moderator at: 2/8/2011 1:21 PMnew subject after splitting |
2/8/2011 6:01 PM | |
Joined: 1/28/2009 Last visit: 7/11/2024 Posts: 6844 Rating: (1363) |
Also check this link: I wanna know when DP Slave has a failure - OB86BR |
2/9/2011 6:17 AM | |
Thanks a ton Sir.My problem is resolved.Surely my problem with your answer will serve asa good lesson for the novices. |
