11/14/2017 11:12 AM | |
Posts: 19 Rating:
No idea...? |
11/28/2017 4:08 PM | |
Posts: 648 Rating:
Hey janjedlicka, how many elements do you use in the PLC array? WinCC comfort you can also write a vbs script to export your data through a csv file. Application example"How on a Windows-based panel can you use a script to save and read out data in a text file?" shows how it works for panel-based (WinCC Comfort - WindowsCE). Application example "How do you store data with a script in a file with WinCC (TIA Portal) PC Runtime?"shows how it works for WinCC RT Advanced (Windows) Also the application example "How do you read out or write tag values with an Excel application?" could be helpful for you. https://support.industry.siemens.com/cs/ww/en/view/69846238 With best regards rh1990 |
