4/11/2024 4:46 AM | |
Joined: 3/14/2008 Last visit: 8/13/2024 Posts: 2084 Rating: (931)
Hi, My experience is that the "Interconnection to" column only shows interconnections between technological I/O (green background). The "Reference block variable" column should list connections to blocks with normal I/O. |
